跳转到主内容
HTC One Motherboard Replacement
你所需要的
  1. HTC One Motherboard Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Use the plastic opening tool to loosen the adhesive from the crease surrounding the screen.
    • The volume button is a good place to begin, it should come right out as you pry.
  2. HTC One Motherboard Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool into the crack around the screen, on only the top, left and right sides.
    • Applying heat with the iOpener or a heat gun can speed this process.
  3. HTC One Motherboard Replacement: 步骤 3 中的图像 1,1
    • Once the screen has been loosened on the top, left and right edges, lift the screen. It will remain attached at the bottom on a hinge.
    • The screen will remain attached to this hinge until the final step.
  4. HTC One Motherboard Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the volume button. Loosen the back panel of the phone with the plastic opening tool. Begin loosening and prying in the space where the battery was.
  5. HTC One Motherboard Replacement: 步骤 5 中的图像 1,1
    • Once the crease has been loosened all around, pry the back panel open and lift until it can be removed.
  6. HTC One Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove tape to expose #000 screws, remove all screws.
    • Use the #000 bit screwdriver
  7. HTC One Motherboard Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Reach beneath the motherboard with the tweezers, grip it and lift.
    • Lift with care, the motherboard is not completely disconnected yet.
    • Remove the tape connecting the motherboard to the phone and gently lift it out.
结论
14等其他人完成本指南。
Meghan
于09/23/14注册
479 声望
撰写一个指南
团队
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G1
4 名成员
创作了7篇指南
2条评论
Where can I buy a motherboard to do the replacement?
Askateth - 回复
Will changing the motherboard fix the pink tint in my camera?
mmm50592 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 28
总计 14,993
