简介
This repair guide will show you step-by-step how to take off the rear casing of your HTC One Mini and safely remove your current rear camera.
你所需要的
Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
Remove the lower speaker cover.
Remove two Phillips screws.
Remove the motherboard and place it so that the rear camera is face down.
2等其他人完成本指南。
2条评论
where can I get the rear camera? what is te number part. tks
