跳转到主内容
加入维修社区 - 创建账户
HTC One Mini Motherboard Replacement
你所需要的
  1. HTC One Mini Motherboard Replacement, iOpener Heating: 步骤 1 中的图像 1,1
    • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
  2. HTC One Mini Motherboard Replacement, Remove Speaker Grills: 步骤 2 中的图像 1,1
    • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
    • Remove the lower speaker cover.
  3. HTC One Mini Motherboard Replacement, Remove Screw: 步骤 3 中的图像 1,3 HTC One Mini Motherboard Replacement, Remove Screw: 步骤 3 中的图像 2,3 HTC One Mini Motherboard Replacement, Remove Screw: 步骤 3 中的图像 3,3
    • Remove the screw under the speaker cover using a T6 Torx screwdriver.
  4. HTC One Mini Motherboard Replacement: 步骤 4 中的图像 1,3 HTC One Mini Motherboard Replacement: 步骤 4 中的图像 2,3 HTC One Mini Motherboard Replacement: 步骤 4 中的图像 3,3
    • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
    • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
  5. HTC One Mini Motherboard Replacement, Separate Rear Case: 步骤 5 中的图像 1,2 HTC One Mini Motherboard Replacement, Separate Rear Case: 步骤 5 中的图像 2,2
    • Remove the rear case from the phone.
  6. HTC One Mini Motherboard Replacement, Remove Screws: 步骤 6 中的图像 1,3 HTC One Mini Motherboard Replacement, Remove Screws: 步骤 6 中的图像 2,3 HTC One Mini Motherboard Replacement, Remove Screws: 步骤 6 中的图像 3,3
    • Remove the two Phillips screws securing the battery connector.
  7. HTC One Mini Motherboard Replacement: 步骤 7 中的图像 1,2 HTC One Mini Motherboard Replacement: 步骤 7 中的图像 2,2
    • Disconnect the battery by prying the metal cover straight up.
  8. HTC One Mini Motherboard Replacement, Remove screws: 步骤 8 中的图像 1,3 HTC One Mini Motherboard Replacement, Remove screws: 步骤 8 中的图像 2,3 HTC One Mini Motherboard Replacement, Remove screws: 步骤 8 中的图像 3,3
    • Remove two Phillips screws.
    • The screw on the upper right corner secures a tiny golden washer. Remove this washer.
  9. HTC One Mini Motherboard Replacement, Remove Screws: 步骤 9 中的图像 1,3 HTC One Mini Motherboard Replacement, Remove Screws: 步骤 9 中的图像 2,3 HTC One Mini Motherboard Replacement, Remove Screws: 步骤 9 中的图像 3,3
    • Remove the two small black Phillips screws.
  10. HTC One Mini Motherboard Replacement, Remove Screws: 步骤 10 中的图像 1,3 HTC One Mini Motherboard Replacement, Remove Screws: 步骤 10 中的图像 2,3 HTC One Mini Motherboard Replacement, Remove Screws: 步骤 10 中的图像 3,3
    • Remove two more Phillips screws.
  11. HTC One Mini Motherboard Replacement, Remove protective foil.: 步骤 11 中的图像 1,3 HTC One Mini Motherboard Replacement, Remove protective foil.: 步骤 11 中的图像 2,3 HTC One Mini Motherboard Replacement, Remove protective foil.: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
  12. HTC One Mini Motherboard Replacement: 步骤 12 中的图像 1,2 HTC One Mini Motherboard Replacement: 步骤 12 中的图像 2,2
    • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
    • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
  13. HTC One Mini Motherboard Replacement: 步骤 13 中的图像 1,3 HTC One Mini Motherboard Replacement: 步骤 13 中的图像 2,3 HTC One Mini Motherboard Replacement: 步骤 13 中的图像 3,3
    • Peel off the silver strip with your tweezers.
    • Using your hands, detach the black strip from the board without removing it.
  14. HTC One Mini Motherboard Replacement: 步骤 14 中的图像 1,2 HTC One Mini Motherboard Replacement: 步骤 14 中的图像 2,2
    • Detach carefully with your tweezers the volume buttons.
    • Detach the power button with your tweezers.
  15. HTC One Mini Motherboard Replacement: 步骤 15 中的图像 1,3 HTC One Mini Motherboard Replacement: 步骤 15 中的图像 2,3 HTC One Mini Motherboard Replacement: 步骤 15 中的图像 3,3
    • Identify the screw behind the cable.
    • Remove the screw using a Phillips screwdriver.
  16. HTC One Mini Motherboard Replacement: 步骤 16 中的图像 1,2 HTC One Mini Motherboard Replacement: 步骤 16 中的图像 2,2
    • Lift the motherboard, but don't try to remove it completely yet.
    • Handle the board only by the edges.
  17. HTC One Mini Motherboard Replacement: 步骤 17 中的图像 1,3 HTC One Mini Motherboard Replacement: 步骤 17 中的图像 2,3 HTC One Mini Motherboard Replacement: 步骤 17 中的图像 3,3
    • Using your tweezers, remove the black square located in the power button.
    • Remove the motherboard completely.
结论
Daniela Delgado
于09/22/14注册
577 声望
创作了2篇指南
团队
USF Tampa, Team 3-4, Brown Fall 2014 USF Tampa, Team 3-4, Brown Fall 2014 的会员
USFT-BROWN-F14S3G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 44
总计 5,325
