简介
Follow the instructions in this repair guide to successfully remove the rear case of your HTC One Mini, locate the phone's battery, and remove it so that a new one may replace it.
你所需要的
Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
Remove the lower speaker cover.
Remove two Phillips screws.
Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
Using the spudger, use force to detach and remove the speaker.
11等其他人完成本指南。
6条评论
Please tell me,can i use battery from htc one mini 2 in htc one mini? I just want increase the battery capacity from 1800 to 2100.thanks for the answer
I completed the steps as described and have an issue with my display now. I tried to start the device before pressing it in the back cover to check whether it works or not. It seems to work, but the display don't. Which cable is that of the display and / or what could have gone wrong? Thx!
I changed the battery, but now, the sound doesn't works. The microphone and the diffuser do not work. What can I do ?
Did this battery exchange few days ago and there is some missing information here.
Between step 15 and step 16 the author also disconnected 4 more plugs in the bottom left of the phone (lying on the screen):
- The big one which is over the screwdriver in the picture of step 15. This can be pulled out sideways.
- The one which cable goes over the screw which is removed in step 15 (white plug with the red/black wires coming out going to the “vibration generator”). I carefully wiggled it out with a tweezer on the plug itself, but you may also go beneath the cables and gently pull it upwards.
- A similar one is a little bit further to the bottom. Use the same technique here.
- Another plug is at the left side. This one can be pulled out sideways.
All 4 of these plugs can be seen in the picutres above (e.g. pic from step 15). They were detached between 15 and 16 without a notice. Only then can you remove the motherboard as shown in step 16.
Hope this info helps anyone.
Max Planck - 回复
