本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
Set the cardholders aside.
Use a metal spudger to pry up the left edge of the upper grey front plate.
Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
Peel off the long yellow pieces of tape on the right and left side of the copper plate.
Using the narrow plastic prying tool, pry up the rectangle connector covered in black foam
另外一个人完成了本指南。
