跳转到主内容
加入维修社区 - 创建账户
HTC One Max Back Case Replacement
你所需要的
  1. HTC One Max Back Case Replacement, Back Case: 步骤 1 中的图像 1,1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Back Case Replacement: 步骤 2 中的图像 1,2 HTC One Max Back Case Replacement: 步骤 2 中的图像 2,2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Back Case Replacement: 步骤 3 中的图像 1,1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Back Case Replacement: 步骤 4 中的图像 1,2 HTC One Max Back Case Replacement: 步骤 4 中的图像 2,2
    • Use the small plastic opening tool to pry between the screen and the rear case.
结论
4等其他人完成本指南。
Andrew Keller
于09/23/14注册
1,131 声望
创作了5篇指南
团队
USF Tampa, Team 11-3, Blackwell Fall 2014 USF Tampa, Team 11-3, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S11G3
4 名成员
创作了7篇指南
5指南评论
any idea where i can purchase that back case?
omair - 回复 分享
The "Tools" section of the guide lists a Y0 screwdriver as required but in the steps it says Y1. Now I have a Y0 screwdriver i can't do anything with and i have to order a Y1. Hopefully that is accurate.
khaydin - 回复 分享
Soooo... unless your HTC One MAX is completely different from the Sprint one i'm trying to replace the back on, both the Y0 and Y1 screw drivers are WRONG for this phone. They are both a bit too big to work on the screws. Now I've bought TWO screw drivers from you guys that were incorrect. Guess i'm gonna need to go out and buy a tri-wing screw driver set.
khaydin - 分享
You need a #Y00 which is smaller then a #Y0 and #Y1 .
Leonturner21 - 分享
The site tells you to use a #Y00 and it does work for any HTC One Max
Leonturner21 - 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 33
过去 30 天: 94
总计 4,308
