跳转到主内容
加入维修社区 - 创建账户
HTC One Camera Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. HTC One Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Use the plastic opening tool to scrape and loosen the adhesive from the crease surrounding the screen.
    • A good place to start is the volume button and it should come right out as you pry.
  2. HTC One Camera Replacement: 步骤 2 中的图像 1,1
    • Wedge the plastic opening tool into the crack around the screen on the top, left and right sides.
    • This step can be sped up by using a heat gun or iOpener to heat up the glue.
  3. HTC One Camera Replacement: 步骤 3 中的图像 1,1
    • Lift along its hinge.
  4. HTC One Camera Replacement: 步骤 4 中的图像 1,1
    • Gently remove the volume button. Using the plastic opening tool, loosen the back panel of the phone. Begin in the space where the battery was and work around the phone, following the crease of the back panel.
  5. HTC One Camera Replacement: 步骤 5 中的图像 1,1
    • Pry the back open once loose and lift. The back panel will come off with time.
  6. HTC One Camera Replacement: 步骤 6 中的图像 1,1
    • Remove all the screws with a #000 Phillip screw driver.
    • Some screws are hidden by tape so remove the tape and check for screws.
  7. HTC One Camera Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to get underneath the mother board to lift.
  8. HTC One Camera Replacement: 步骤 8 中的图像 1,1
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it).
    • Lift the camera out of the motherboard and replace.
结论
5等其他人完成本指南。
Jeremy
于09/23/14注册
1,862 声望
创作了2篇指南
团队
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G1
4 名成员
创作了7篇指南
1指南评论
Will the adhesive be good enough to seal the device again?
krugern - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 12,730
