跳转到主内容
加入维修社区 - 创建账户
HTC One Camera Lens Replacement
你所需要的
  1. HTC One Camera Lens Replacement, Camera Lens: 步骤 1 中的图像 1,3 HTC One Camera Lens Replacement, Camera Lens: 步骤 1 中的图像 2,3 HTC One Camera Lens Replacement, Camera Lens: 步骤 1 中的图像 3,3
    • Find an appropriate lens cover on parts4repair.com, amazon, etrade supply, or other online sources. Reading various blogs there are a few that people seem to be using. Below are the common lens covers that are being used:
    • #1 Option: HTC One Lens Assembly
    • #2 Option: HTC One X Camera Lens
    • #3 Option: HTC Evo 4G Camera Lens
    • This guide outlines using all three and weighs the pros and cons of each
    • At the time of writing this the original HTC One Lens assembly was hard to find, but it's the best option for lens replacement. So if this is still the case then the HTC One X lens is the second best option and the Evo 4G is the third best option.
    • On Amazon, eBay, eTrade supply the HTC One Rear Housing is being sold and contained on this is the lens assembly, this can be purchased and the lens assembly removed from this.
    • The downside of options #2 and #3 is that the lens protrudes from the back of the phone and may lead to scuffing of the lens. If a protective case is on the phone then scuffing of the lens is not a concern and any of the options will work just fine
  2. HTC One Camera Lens Replacement, Remove the Broken Lens: 步骤 2 中的图像 1,3 HTC One Camera Lens Replacement, Remove the Broken Lens: 步骤 2 中的图像 2,3 HTC One Camera Lens Replacement, Remove the Broken Lens: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the broken glass using tweezers and an exacto knife.
    • If your new lens has adhesive on it, ensure you remove all the old adhesive from the frame so the lens doesn't stick out unnecessarily and so forms a tighter seal
  3. HTC One Camera Lens Replacement, Best Option: HTC One Lens Assembly: 步骤 3 中的图像 1,3 HTC One Camera Lens Replacement, Best Option: HTC One Lens Assembly: 步骤 3 中的图像 2,3 HTC One Camera Lens Replacement, Best Option: HTC One Lens Assembly: 步骤 3 中的图像 3,3
    • Shown here is the HTC One Rear Housing that I bought separately on eBay. Its recommended to buy the "HTC One Rear Housing" on eBay, eTrade supply, Amazon or other online retailer for ~$15-25 USD, then remove the lens assembly from this housing and use this lens assembly to replace the broken lens.
    • Lightly glued to the housing is the lens assembly that will be needed to replace the broken lens
    • Using tweezers gently peel up from the side shown in the picture. Place the tweezers below the lens assembly on the camera flash side and gently pull up. It easily comes up.
    • Also, a contributor posted a video walk through: http://www.youtube.com/watch?v=MQsPvdo2c...
  4. HTC One Camera Lens Replacement, Best Option: HTC One Lens Assembly: 步骤 4 中的图像 1,3 HTC One Camera Lens Replacement, Best Option: HTC One Lens Assembly: 步骤 4 中的图像 2,3 HTC One Camera Lens Replacement, Best Option: HTC One Lens Assembly: 步骤 4 中的图像 3,3
    • In order to remove the lens from the lens assembly twist the entire assembly in order to bend the plastic
    • Be careful not to break the lens
    • Peel the lens out of the assembly, it is held in with a soft adhesive
    • Another slightly different method used by "Bruce" in the comments: to remove the lens from the assembly, gently - very gently - flex the plastic housing with a little pressure on the back side of the lens using a cotton bud (q-tip) until the edge of the lens is exposed, you can then carefully use a fingernail to pry the lens free.
    • Rotate the housing with your fingernail just under the edge of the lens and it will easily pop free.
  5. HTC One Camera Lens Replacement, Best Option: HTC One Lens Assembly: 步骤 5 中的图像 1,3 HTC One Camera Lens Replacement, Best Option: HTC One Lens Assembly: 步骤 5 中的图像 2,3 HTC One Camera Lens Replacement, Best Option: HTC One Lens Assembly: 步骤 5 中的图像 3,3
    • After peeling the lens from the assembly some of the soft adhesive is left on the lens
    • Using the adhesive that is remaining on the lens push the lens into the housing body and the adhesive will hold it in place.
    • The Lens cover fits flush inside the housing and is the best option for replacement because it does not protrude out of the housing
  6. HTC One Camera Lens Replacement, 2nd Best Option: HTC One X Lens Replacement: 步骤 6 中的图像 1,2 HTC One Camera Lens Replacement, 2nd Best Option: HTC One X Lens Replacement: 步骤 6 中的图像 2,2
    • The HTC One X Lens replacement has the same diameter as the HTC One body and fits the hole nicely
    • The one downside is that it sticks out about a millimeter and will lead to scuffing of the lens over time.
    • If a protective case is used on the phone, then scuffing of the lens should not be a problem and this lens cover option will work just fine
  7. HTC One Camera Lens Replacement, 3rd Best Option: Evo 4G Lens Replacement: 步骤 7 中的图像 1,3 HTC One Camera Lens Replacement, 3rd Best Option: Evo 4G Lens Replacement: 步骤 7 中的图像 2,3 HTC One Camera Lens Replacement, 3rd Best Option: Evo 4G Lens Replacement: 步骤 7 中的图像 3,3
    • The third best option. The Evo 4G lens replacement has a foam adhesive on one side. Remove the release liner from this side to expose the adhesive.
    • Place the lens replacement over the camera hole. The foam adhesive will be facing down against the body of the phone and the "8 Megapixel" writing will be facing outward. Push gently against the lens replacement to make sure it adheres well to the body.
    • Remove the plastic film on the outside "8 Megapixels" side.
    • The adhesive sticks really well in my experience, it can be removed and put back in place multiple times if you dont like how it was placed originally.
  8. HTC One Camera Lens Replacement, 3rd Best Option: Evo 4G Lens Replacement: 步骤 8 中的图像 1,3 HTC One Camera Lens Replacement, 3rd Best Option: Evo 4G Lens Replacement: 步骤 8 中的图像 2,3 HTC One Camera Lens Replacement, 3rd Best Option: Evo 4G Lens Replacement: 步骤 8 中的图像 3,3
    • As you can see it does not fit perfectly and there is a small gap around the outside and the lens protrudes slightly further from the body of the phone.
    • Although the fit is not perfect, the camera takes the exact same quality photos because the light can pass through the glass lens exactly as it did with the original lens cover.
    • Because it protrudes further from the body, its prone to getting scratches.
    • I used this lens replacement for a month (before finding the HTC One lens assembly) and it stayed in place really well and did not fall out. As you can see in the bright close up image there are light scuffs on the lens cover.
    • If a protective case is used on the phone, then scuffing of the lens will not be a problem and this lens cover option will work just fine. Its just a little ugly is all.
结论
Theres a number of different lens covers that might work, this guide outlines how to use three different ones
9等其他人完成本指南。
alcs99
于09/10/13注册
5,075 声望
创作了6篇指南
16指南评论
Where did you get the original htc one lens assembly?
Raph Cout - 回复
Raph, thanks for the heads up that its still difficult to find the htc one lens assembly. When I wrote this I had hoped it would become readily available eventually, but I guess not. I updated the guide to show how to remove the original HTC One lens assembly from the HTC One Rear Housing, which you can buy on eBay, eTrade Supply, or other online sources for about $12-20 USD.
alcs99 -
How did you get the back off? I saw some video's of people having a hard time getting it of and damaging it while trying. Can you tell me how you managed to get it off without damaging?
Vivian - 回复
The back of the phone does not need to be removed, the picture in step 3 is the "HTC One Rear Housing" that I bought separately on eBay. This piece is sold for $15-30 and you will need to buy this to pull off its intact glass lens and use this to replace the broken one.
alcs99 -
Hello! I just finished this project and videotaped it. Its not great, but it was my first time!
Calahan Hempe - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 57
过去 30 天: 103
总计 105,134
