简介
In this guide we will go through various steps in taking apart the HTC phone in order to replace the LCD.
你所需要的
Place the prying tool into the notch at the bottom of the case and pull up to remove.
Use the plastic prying tool in the upper left-hand corner notch of the battery to remove.
Remove the two T5x5mm Screws with the T5 Torx Screw driver.
Remove the one Phillips screw with the Phillips #00 Screwdriver.
Use the plastic opening tools to remove the back case.
There are four T5x5mm screws. Use the T5 Torx Screwdriver to remove them.
Using the plastic opening tools, remove the Wifi antenna.
There are three button ribbons on the phone that need to be pulled down off of the case.
With the plastic opening tools, pull the button ribbons down away from the frame without completely removing them.
Do not take the digitizer fully off as it is still connected by the ribbon.
Use the iOpener tool to heat up the LCD adhesive.
Using the iOpener kit and the plastic opening tools again, remove the LCD. The LCD is now ready to be replaced. Make sure to have more adhesive that usually comes with the replacement to make sure the LCD and digitizer will be secure.
2等其他人完成本指南。
