跳转到主内容
加入维修社区 - 创建账户
HTC MyTouch 4G LCD Replacement
你所需要的
  1. HTC MyTouch 4G LCD Replacement, Flip Phone Over: 步骤 1 中的图像 1,1
    • Flip your phone over and hold the phone with the back facing you.
    询问修复机器人
  2. HTC MyTouch 4G LCD Replacement, Remove the back case.: 步骤 2 中的图像 1,1
    • Place the prying tool into the notch at the bottom of the case and pull up to remove.
    询问修复机器人
  3. HTC MyTouch 4G LCD Replacement, Remove the battery: 步骤 3 中的图像 1,2 HTC MyTouch 4G LCD Replacement, Remove the battery: 步骤 3 中的图像 2,2
    • Use the plastic prying tool in the upper left-hand corner notch of the battery to remove.
    询问修复机器人
  4. HTC MyTouch 4G LCD Replacement, Removing Screws: 步骤 4 中的图像 1,1
    • Remove the two T5x5mm Screws with the T5 Torx Screw driver.
    • Remove the one Phillips screw with the Phillips #00 Screwdriver.
    询问修复机器人
  5. HTC MyTouch 4G LCD Replacement, Removing back case.: 步骤 5 中的图像 1,3 HTC MyTouch 4G LCD Replacement, Removing back case.: 步骤 5 中的图像 2,3 HTC MyTouch 4G LCD Replacement, Removing back case.: 步骤 5 中的图像 3,3
    • Use the plastic opening tools to remove the back case.
    • There are four T5x5mm screws. Use the T5 Torx Screwdriver to remove them.
    • Using the plastic opening tools, remove the Wifi antenna.
    询问修复机器人
  6. HTC MyTouch 4G LCD Replacement, Removing four T5 Screws: 步骤 6 中的图像 1,2 HTC MyTouch 4G LCD Replacement, Removing four T5 Screws: 步骤 6 中的图像 2,2
    • There are three button ribbons on the phone that need to be pulled down off of the case.
    • With the plastic opening tools, pull the button ribbons down away from the frame without completely removing them.
    询问修复机器人
  7. HTC MyTouch 4G LCD Replacement: 步骤 7 中的图像 1,3 HTC MyTouch 4G LCD Replacement: 步骤 7 中的图像 2,3 HTC MyTouch 4G LCD Replacement: 步骤 7 中的图像 3,3
    • After making sure the button ribbons are away from the frame, insert the plastic opening tool into the frame and remove it.
    • Remove two Philips screws holding the Motherboard in place.
    询问修复机器人
  8. HTC MyTouch 4G LCD Replacement: 步骤 8 中的图像 1,2 HTC MyTouch 4G LCD Replacement: 步骤 8 中的图像 2,2
    • Three ribbon cables and the vibration motor need to be disconnected from the motherboard.
    • Using the plastic opening tools, pull up on the power button ribbon to gently detach it.
    • Remove the vibration motor by gently pulling it off of the motherboard.
    询问修复机器人
  9. HTC MyTouch 4G LCD Replacement: 步骤 9 中的图像 1,3 HTC MyTouch 4G LCD Replacement: 步骤 9 中的图像 2,3 HTC MyTouch 4G LCD Replacement: 步骤 9 中的图像 3,3
    • Remove the digitizer ribbon cable with the plastic opening tools.
    • Remove the LCD ribon cable from its connector.
    • It is now safe to release the Motherboard from the clips holding it in place. Start at the top clip of the phone and move your way around gently releasing each clip.
    询问修复机器人
  10. HTC MyTouch 4G LCD Replacement: 步骤 10 中的图像 1,3 HTC MyTouch 4G LCD Replacement: 步骤 10 中的图像 2,3 HTC MyTouch 4G LCD Replacement: 步骤 10 中的图像 3,3
    • Do not lift the Motherboard off the phone. The LCD Ribbon is still connected to it.
    • Lift the Motherboard towards the left to expose the LCD clamp connector.
    • Open the clamp connector of the LCD ribbon by carefully pulling it up with the plastic opening tools.
    询问修复机器人
  11. HTC MyTouch 4G LCD Replacement: 步骤 11 中的图像 1,1
    • The motherboard is now removed.
    询问修复机器人
  12. HTC MyTouch 4G LCD Replacement, LCD: 步骤 12 中的图像 1,3 HTC MyTouch 4G LCD Replacement, LCD: 步骤 12 中的图像 2,3 HTC MyTouch 4G LCD Replacement, LCD: 步骤 12 中的图像 3,3
    • Put the LCD side of the phone facing upward.
    • Use the iOpener to heat and loosen the adhesive up that is holding the digitizer in place.
    • Move the plastic opening tools along the outside edge of the digitizer to loosen it more and remove.
    询问修复机器人
  13. HTC MyTouch 4G LCD Replacement: 步骤 13 中的图像 1,3 HTC MyTouch 4G LCD Replacement: 步骤 13 中的图像 2,3 HTC MyTouch 4G LCD Replacement: 步骤 13 中的图像 3,3
    • Do not take the digitizer fully off as it is still connected by the ribbon.
    • Use the iOpener tool to heat up the LCD adhesive.
    • Using the iOpener kit and the plastic opening tools again, remove the LCD. The LCD is now ready to be replaced. Make sure to have more adhesive that usually comes with the replacement to make sure the LCD and digitizer will be secure.
    询问修复机器人
结论
2等其他人完成本指南。
leo
于01/30/15注册
334 声望
创作了3篇指南
团队
USF Tampa, Team 16-5, Watkins Spring 2014 USF Tampa, Team 16-5, Watkins Spring 2014 的会员
USFT-WATKINS-S14S16G5
2 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 43
总计 617
