跳转到主内容
HTC Maple 100 Internal Ear Speaker Replacement
你所需要的
  1. HTC Maple 100 Internal Ear Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 2 中的图像 1,1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 3 中的图像 1,2 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 3 中的图像 2,2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 Internal Ear Speaker Replacement, Back Panel: 步骤 4 中的图像 1,2 HTC Maple 100 Internal Ear Speaker Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 6 中的图像 1,3 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 6 中的图像 2,3 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 6 中的图像 3,3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 Internal Ear Speaker Replacement, Motherboard: 步骤 7 中的图像 1,2 HTC Maple 100 Internal Ear Speaker Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Remove the one 3.3mm Phillips #00 screw.
  8. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 8 中的图像 1,2 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 8 中的图像 2,2
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  9. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 9 中的图像 1,2 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 9 中的图像 2,2
    • Peel off the yellow piece of tape from the phone.
  10. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 10 中的图像 1,3 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 10 中的图像 2,3 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 10 中的图像 3,3
    • Flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers.
  11. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 11 中的图像 1,2 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 11 中的图像 2,2
    • Split apart the motherboard and front panel.
    • Remove the other yellow piece of tape off of the end of the ribbon cable.
  12. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 12 中的图像 1,2 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 12 中的图像 2,2
    • Gently pull on the ribbon cable to separate the motherboard.
  13. HTC Maple 100 Internal Ear Speaker Replacement, Internal Ear Speaker: 步骤 13 中的图像 1,1
    • Locate the internal speaker at the top center of the phone.
  14. HTC Maple 100 Internal Ear Speaker Replacement: 步骤 14 中的图像 1,2 HTC Maple 100 Internal Ear Speaker Replacement: 步骤 14 中的图像 2,2
    • Using the plastic opening tool, carefully pry out the internal speaker.
结论
Alyssa Thompson
于10/04/11注册
11 声望
创作了2篇指南
团队
Cal Poly, Team 20-29, Maness Fall 2011 Cal Poly, Team 20-29, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G29
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 759
