简介
Remove 4 Torx screws and 2 #00 Philps
  1. First remove the back cover of your phone to expose the battery.
    • First remove the back cover of your phone to expose the battery.
  2. Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
    • Turn the phone over and remove the battery by using your thumb to push forward on the battery and then lift it.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Take the battery out When reassembling, make sure that the battery contacts match up.
    • Take the battery out
    • When reassembling, make sure that the battery contacts match up.
  5. Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
  6. Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
    • Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
  7. Use the plastic opening tool to pry the clips off Insert the plastic opening tool along the seams at different points to it pry up This may require a bit of force. The USB port cover may fall off in this step.
    • Use the plastic opening tool to pry the clips off
    • Insert the plastic opening tool along the seams at different points to it pry up
    • This may require a bit of force. The USB port cover may fall off in this step.
结论
Andrew Van Meter
于2011年10月06日注册
24 信誉积分
创作了3篇指南
团队
Cal Poly, Team 20-29, Maness Fall 2011 Cal Poly, Team 20-29, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G29
4 名成员
创作了9篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 708
