跳转到主内容
加入维修社区 - 创建账户
HTC Magic Speaker Replacement
你所需要的
  1. HTC Magic Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 HTC Magic Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 HTC Magic Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Open the phone by removing it's backcover (battery door) and the battery.
    • REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
  2. HTC Magic Speaker Replacement: 步骤 2 中的图像 1,1
    • Unscrew the six screws with a Torx T5 screwdriver.
  3. HTC Magic Speaker Replacement: 步骤 3 中的图像 1,2 HTC Magic Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the antenna (use the little gap at the top ).
    • Use the iPod opening tools (or your fingernails) to remove the hosuing by running along the seam bit by bit. It's easiest to start somewhere in the middle, then work your way across the top.
    • The housing is held by plastic clips, so be careful since you don't want to break these.
    • Carefully lift the front housing from the back.
  4. HTC Magic Speaker Replacement: 步骤 5 中的图像 1,2 HTC Magic Speaker Replacement: 步骤 5 中的图像 2,2
    • The rear housing should look like the picture on the left. The speaker part is at the top.
    • Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • Be sure not to touch any part of the speaker except the black plastic parts.
结论
LucasJV
于05/18/10注册
741 声望
创作了3篇指南
1指南评论
Where can I buy a speaker's set for the HTC Magic, please?
Miguel Ponce - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 45
总计 10,952
