跳转到主内容
加入维修社区 - 创建账户
HTC Inspire 4G Display Assembly Replacement
你所需要的
  1. HTC Inspire 4G Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Remove battery cover using a plastic opening tool or finger nail.
    • Slide opening tool to release clasps and remove battery cover.
  2. HTC Inspire 4G Display Assembly Replacement: 步骤 2 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 2 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 2 中的图像 3,3
    • With the cover removed, the battery will fall freely with a gentle shake.
  3. HTC Inspire 4G Display Assembly Replacement: 步骤 3 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 3 中的图像 2,2
    • Remove SIM card cover by simultaneously squeezing cover and pulling it off of the phone.
  4. HTC Inspire 4G Display Assembly Replacement: 步骤 4 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 4 中的图像 2,2
    • Slide SIM card out.
  5. HTC Inspire 4G Display Assembly Replacement: 步骤 5 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 5 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 5 中的图像 3,3
    • Remove Micro SD card by pushing it in to the phone. Spring-loaded clasp will release the card.
  6. HTC Inspire 4G Display Assembly Replacement: 步骤 6 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 6 中的图像 2,2
    • Use a curved metal spudger to remove GPS cover.
    • Probe underside of GPS cover until you can force a small opening between GPS cover and back cover of phone.
  7. HTC Inspire 4G Display Assembly Replacement: 步骤 7 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 7 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 7 中的图像 3,3
    • Insert plastic opening tool into gap between GPS cover and back cover of phone. Slide tool along GPS cover and pry the piece off.
  8. HTC Inspire 4G Display Assembly Replacement: 步骤 8 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 8 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 8 中的图像 3,3
    • Remove "VOID" sticker from screw.
    • If your phone has a warranty, removing "VOID" sticker will void your warranty.
  9. HTC Inspire 4G Display Assembly Replacement: 步骤 9 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 9 中的图像 2,2
    • Remove four 2.2mm T5 torx screws.
    • Remove one 4.5mm T5 torx screw.
  10. HTC Inspire 4G Display Assembly Replacement: 步骤 10 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 10 中的图像 2,2
    • Remove display cable shield.
    • Insert probing tool into screw hole and pull shield.
    • Be careful! This piece is made of thin, springy metal and will fly across the room if you remove it too forcefully.
  11. HTC Inspire 4G Display Assembly Replacement: 步骤 11 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 11 中的图像 2,2
    • Peel off manufacturer's information sticker.
  12. HTC Inspire 4G Display Assembly Replacement: 步骤 12 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 12 中的图像 2,2
    • Lift volume button assembly out of the back case.
    • Work slowly! Initially, you must lever the assembly from the ribbon cable attaching it to the upper logic board. The cable is delicate.
  13. HTC Inspire 4G Display Assembly Replacement: 步骤 13 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 13 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 13 中的图像 3,3
    • Push up on the back cover, wiggling cover back and forth, until it slides off.
  14. HTC Inspire 4G Display Assembly Replacement: 步骤 14 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 14 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 14 中的图像 3,3
    • Remove "VOID" sticker.
    • If your phone has a warranty, removing the "VOID" sticker will void your warranty.
    • Remove three 2.4mm T5 torx screws.
  15. HTC Inspire 4G Display Assembly Replacement: 步骤 15 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 15 中的图像 2,2
    • Apply pressure to the bottom of the plastic logic board shield and it will pop right off.
  16. HTC Inspire 4G Display Assembly Replacement: 步骤 16 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 16 中的图像 2,2
    • Remove rubber spacer.
  17. HTC Inspire 4G Display Assembly Replacement: 步骤 17 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 17 中的图像 2,2
    • Peel off Mylar tape.
  18. HTC Inspire 4G Display Assembly Replacement: 步骤 18 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 18 中的图像 2,2
    • Peel off electrical tape.
  19. HTC Inspire 4G Display Assembly Replacement: 步骤 19 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 19 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 19 中的图像 3,3
    • Pry display assembly connector off of lower logic board.
  20. HTC Inspire 4G Display Assembly Replacement: 步骤 20 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 20 中的图像 2,2
    • Remove metal bracket.
  21. HTC Inspire 4G Display Assembly Replacement: 步骤 21 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 21 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 21 中的图像 3,3
    • Remove speaker.
    • During reassembly, be careful with the spring connectors on the reverse side of the speaker unit. They are bent easily.
    • This rubber spacer is held on by a weak adhesive. Be careful with this during reassembly, as it may catch and crumple as you put the back panel back the phone.
  22. HTC Inspire 4G Display Assembly Replacement: 步骤 22 中的图像 1,1
    • Remove one 1.5mm #00 Phillips screw.
    • Remove two 2.5mm T5 torx screws.
  23. HTC Inspire 4G Display Assembly Replacement: 步骤 23 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 23 中的图像 2,2
    • Remove earpiece speaker connector.
  24. HTC Inspire 4G Display Assembly Replacement: 步骤 24 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 24 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 24 中的图像 3,3
    • Pry off Bluetooth coaxial cable connector.
    • Unwind Bluetooth coaxial cable from plastic camera shield.
  25. HTC Inspire 4G Display Assembly Replacement: 步骤 25 中的图像 1,3 HTC Inspire 4G Display Assembly Replacement: 步骤 25 中的图像 2,3 HTC Inspire 4G Display Assembly Replacement: 步骤 25 中的图像 3,3
    • Pry off plastic camera shield.
  26. HTC Inspire 4G Display Assembly Replacement: 步骤 26 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 26 中的图像 2,2
    • Heat black Mylar shield for easier removal.
    • As you can see, we attempted to peel off the Mylar shield before heating it. It required more force than we were comfortable with, so we turned up the heat!
    • Peel off Mylar shield.
  27. HTC Inspire 4G Display Assembly Replacement: 步骤 27 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 27 中的图像 2,2
    • Gently separate upper logic board from mid chassis. The upper logic board is held to the mid chassis by copious amounts of strong adhesive.
  28. HTC Inspire 4G Display Assembly Replacement: 步骤 28 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 28 中的图像 2,2
    • Gently separate lower logic board from mid chassis. The lower logic board is held to the mid chassis by copious amounts of strong adhesive.
  29. HTC Inspire 4G Display Assembly Replacement: 步骤 29 中的图像 1,1
    • Once the adhesive-laden logic boards are separated from the mid chassis, the entire assembly easily comes off.
    • Be careful when handing the logic board assembly. We could have separated out each part, but decided it was a waste of time. The cost of cutting this corner is extra care when handling the logic board assembly.
  30. HTC Inspire 4G Display Assembly Replacement: 步骤 30 中的图像 1,2 HTC Inspire 4G Display Assembly Replacement: 步骤 30 中的图像 2,2
    • Blast the front panel with heat and pry between the display assembly and front panel bezel, working one or several guitar picks around the display assembly.
    • Once the display assembly is loosened from the front panel, it will fall away.
    • The front glass came off easily, but the digitizer was much more difficult to remove. The adhesive holding together the display assembly is much weaker than the adhesive holding the display assembly to the front panel.
    • While creating this guide, I utterly destroyed the front panel bezel and digitizer. Replacing the display assembly was a breeze--but removing the digitizer required nearly a dozen reheats of the front panel. To replace the bezel, you will need a new "mid chassis" (that's the front panel piece the digitizer is so powerfully glued to).
结论
17等其他人完成本指南。
Jeff Snyder
于02/07/13注册
9,271 声望
创作了4篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,153篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 42
总计 5,558
