跳转到主内容
HTC Incredible 2 Power Button Replacement
你所需要的
  1. HTC Incredible 2 Power Button Replacement, Disassembling HTC Incredible 2 Back Panel: 步骤 1 中的图像 1,2 HTC Incredible 2 Power Button Replacement, Disassembling HTC Incredible 2 Back Panel: 步骤 1 中的图像 2,2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. HTC Incredible 2 Power Button Replacement: 步骤 2 中的图像 1,1
    • Remove the rear panel from the phone.
  3. HTC Incredible 2 Power Button Replacement, Battery: 步骤 3 中的图像 1,1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. HTC Incredible 2 Power Button Replacement: 步骤 4 中的图像 1,2 HTC Incredible 2 Power Button Replacement: 步骤 4 中的图像 2,2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  5. HTC Incredible 2 Power Button Replacement, SIM Card: 步骤 5 中的图像 1,2 HTC Incredible 2 Power Button Replacement, SIM Card: 步骤 5 中的图像 2,2
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
  6. HTC Incredible 2 Power Button Replacement: 步骤 6 中的图像 1,2 HTC Incredible 2 Power Button Replacement: 步骤 6 中的图像 2,2
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
  7. HTC Incredible 2 Power Button Replacement, Mid Panel: 步骤 7 中的图像 1,1
    • Remove the seven 1.42 mm Torx T5 screws
  8. HTC Incredible 2 Power Button Replacement: 步骤 8 中的图像 1,2 HTC Incredible 2 Power Button Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
  9. HTC Incredible 2 Power Button Replacement: 步骤 9 中的图像 1,1
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
  10. HTC Incredible 2 Power Button Replacement, Power Button: 步骤 10 中的图像 1,3 HTC Incredible 2 Power Button Replacement, Power Button: 步骤 10 中的图像 2,3 HTC Incredible 2 Power Button Replacement, Power Button: 步骤 10 中的图像 3,3
    • Firmly grasp the power button, located on the upper right corner of the mid panel, and gently lift it up and off the mid panel.
结论
3等其他人完成本指南。
团队
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G53
5 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 770
