当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
Remove both the battery and the SD card (Press SD card in to release)
Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
Insert the flat end between the back and front enclosure, working your way around the rim.
Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
At this point it is a good idea to remove the track ball and enclosure to prevent accidental loss.
To remove the trackball, turn the phone over into your cupped hand and the trackball will fall out.
Using an plastic opening tool, gently pry out the LCD screen from the left side of the enclosure as illustrated.
You many need to gently wiggle the screen out or continue using the plastic opening tool until released.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
