跳转到主内容
HTC Hero LCD Screen Replacement
你所需要的
  1. HTC Hero LCD Screen Replacement, Back Case: 步骤 1 中的图像 1,1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
  2. HTC Hero LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
  3. HTC Hero LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
  4. HTC Hero LCD Screen Replacement: 步骤 4 中的图像 1,2 HTC Hero LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
  5. HTC Hero LCD Screen Replacement, Motherboard: 步骤 5 中的图像 1,2 HTC Hero LCD Screen Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Release the two ribbon cables using a plastic opening tool.
    • Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
  6. HTC Hero LCD Screen Replacement: 步骤 6 中的图像 1,2 HTC Hero LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
  7. HTC Hero LCD Screen Replacement: 步骤 7 中的图像 1,2 HTC Hero LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
  8. HTC Hero LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 1,3 HTC Hero LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 2,3 HTC Hero LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 3,3
    • At this point it is a good idea to remove the track ball and enclosure to prevent accidental loss.
    • To remove the trackball, turn the phone over into your cupped hand and the trackball will fall out.
  9. HTC Hero LCD Screen Replacement: 步骤 9 中的图像 1,3 HTC Hero LCD Screen Replacement: 步骤 9 中的图像 2,3 HTC Hero LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Using an plastic opening tool, gently pry out the LCD screen from the left side of the enclosure as illustrated.
    • You many need to gently wiggle the screen out or continue using the plastic opening tool until released.
结论
团队
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G26
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 2,019
