跳转到主内容
加入维修社区 - 创建账户
HTC Hero Back Case Replacement
你所需要的
  1. HTC Hero Back Case Replacement, Back Case: 步骤 1 中的图像 1,1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
  2. HTC Hero Back Case Replacement: 步骤 2 中的图像 1,1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
  3. HTC Hero Back Case Replacement: 步骤 3 中的图像 1,1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
  4. HTC Hero Back Case Replacement: 步骤 4 中的图像 1,2 HTC Hero Back Case Replacement: 步骤 4 中的图像 2,2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
结论
Max Brown
于01/23/12注册
139 声望
创作了4篇指南
团队
Cal Poly, Team 3-26, Amido Winter 2012 Cal Poly, Team 3-26, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G26
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 2,344
