当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Insert the flat end of a spudger between the midframe and the display.
Slide the spudger along the seam between the frame and the display.
Using the spudger for leverage, carefully pry the midframe away from the display assembly.
This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
As it releases, pull the midframe away from the phone.
The volume control tab may fall off during removal. It can be easily reattached.
Set the phone down on its screen.
Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
Pull the camera flash and cover off of the board.
You may need to peel back the sticker that sits behind the battery.
Work carefully. Excessive force can damage the camera or motherboard.
Now find the AP FPC, one of the smallest connectors on the bottom board.
Pop the small black tab up using tweezers, then unplug the cable.
This step is pretty much irreversible, so do not do this unless you absolutely have to.
Remember peeling back part of that big sticker in the middle? Now you get to take it all the way off.
This may take some time, and the use of the tweezers, but keep at it until the whole sticker is off.
Now find the GPS board in the upper left hand corner of the phone.
Disconnect the white cable from its socket on the motherboard.
The cable does not need to be unplugged from the main bottom board.
This cable is connected to the underside of the bottom board. If it is detached, be sure to reconnect it before reassembling the phone.
If this step does not progress easily, check to see that there are no screws still holding the board in place.
With the cable removed, pop the GPS board out of the phone using tweezers.
Using a spudger, begin to pry the copper colored board in the middle away from the phone to loosen it.
Also pry the small piece that runs under where the volume selector is on the full phone.
There is a connecter cable under the main board, so do not pull it all the way off right away.
Gently pop both the top and bottom boards off of the phone, and turn them over to the left
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
