跳转到主内容
HTC HD2 Midframe Replacement
你所需要的
  1. HTC HD2 Midframe Replacement, Battery: 步骤 1 中的图像 1,1
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Midframe Replacement: 步骤 2 中的图像 1,2 HTC HD2 Midframe Replacement: 步骤 2 中的图像 2,2
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Midframe Replacement, Midframe: 步骤 3 中的图像 1,2 HTC HD2 Midframe Replacement, Midframe: 步骤 3 中的图像 2,2
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Midframe Replacement: 步骤 4 中的图像 1,2 HTC HD2 Midframe Replacement: 步骤 4 中的图像 2,2
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
结论
4等其他人完成本指南。
Sam Luedloff
于04/12/11注册
727 声望
创作了3篇指南
团队
Cal Poly, Team 24-55, Amido Spring 2011 Cal Poly, Team 24-55, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G55
5 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 9,029
