跳转到主内容
HTC Freestyle Screen Replacement
你所需要的
  1. HTC Freestyle Screen Replacement, Remove back cover: 步骤 1 中的图像 1,2 HTC Freestyle Screen Replacement, Remove back cover: 步骤 1 中的图像 2,2
    • Apply pressure to the dark plastic casing and slide the casing downward, off of the phone.
  2. HTC Freestyle Screen Replacement, Open plastic flap.: 步骤 2 中的图像 1,2 HTC Freestyle Screen Replacement, Open plastic flap.: 步骤 2 中的图像 2,2
    • Fold the plastic flap open.
  3. HTC Freestyle Screen Replacement, Reveal the battery: 步骤 3 中的图像 1,2 HTC Freestyle Screen Replacement, Reveal the battery: 步骤 3 中的图像 2,2
    • Pull on the red tab to slide the battery out.
    • Take out the battery.
    • Replace with new battery.
  4. HTC Freestyle Screen Replacement, Remove screws from plastic flap: 步骤 4 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the five screws anchoring the plastic flap to the phone.
    • One of the five screws may be hidden beneath a "Void" sticker to the right of the serial label.
  5. HTC Freestyle Screen Replacement, Remove plastic flap from phone: 步骤 5 中的图像 1,1
    • Once the screws are removed from the plastic flap, the piece should easily come out.
  6. HTC Freestyle Screen Replacement, Remove circuiting panel: 步骤 6 中的图像 1,2 HTC Freestyle Screen Replacement, Remove circuiting panel: 步骤 6 中的图像 2,2
    • After the screws are removed, fold circuit panel upwards, exposing the phone's primary buttons.
    • In order to remove the circuit board you must disconnect the labeled component.
  7. HTC Freestyle Screen Replacement, Remove primary buttons: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Once the back side of the buttons are exposed, they will fall out either by punching them out from the front side, or by using tweezers to pull them out of the back.
  8. HTC Freestyle Screen Replacement, Separate phone housing from electrical components: 步骤 8 中的图像 1,2 HTC Freestyle Screen Replacement, Separate phone housing from electrical components: 步骤 8 中的图像 2,2
    • Rotate your HTC Freestyle so that the main screen is facing upward and toward you.
    • Use a plastic opening tool to pry the screen and electronic internals apart from the main phone housing.
  9. HTC Freestyle Screen Replacement, Remove screws from internal component: 步骤 9 中的图像 1,2 HTC Freestyle Screen Replacement, Remove screws from internal component: 步骤 9 中的图像 2,2
    • Orient the component so that the battery compartment and camera are facing upwards.
    • Use the #00 Phillips screwdriver to remove the exterior screws that are holding the piece together.
    • There should be screws on both lateral sides of the phone as well as one screw in the top corner to the right of the camera
  10. HTC Freestyle Screen Replacement, Separate the internal component into two halves: 步骤 10 中的图像 1,2 HTC Freestyle Screen Replacement, Separate the internal component into two halves: 步骤 10 中的图像 2,2
    • Once the screws are removed, the motherboard can be separated from the other components after prying open the gold-colored clamps hidden underneath the battery compartment.
    • Rotate the phone 180 degrees and pry the second clamp that is located on the other side of the component.
    • The motherboard will then easily be removed from the rest.
  11. HTC Freestyle Screen Replacement, Pry the screen from the front of the phone: 步骤 11 中的图像 1,2 HTC Freestyle Screen Replacement, Pry the screen from the front of the phone: 步骤 11 中的图像 2,2
    • Once the screen and motherboard are separated, use a plastic opening tool to pry along the edges of the touchscreen. **Note, the use of a heat gun/heating element will help loosen the adhesive from behind the screen to make prying less physically straining.
    • The screen should now be fully removed.
结论
团队
USF Tampa, Team 8-3, Leahy Fall 2014 USF Tampa, Team 8-3, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 414
