跳转到主内容
加入维修社区 - 创建账户
HTC Fortress Back Panel Replacement
你所需要的
  1. HTC Fortress Back Panel Replacement, Battery: 步骤 1 中的图像 1,2 HTC Fortress Back Panel Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the back cover of the device by sliding it upward.
    • You may need to remove the phone stylus first.
  2. HTC Fortress Back Panel Replacement: 步骤 2 中的图像 1,2 HTC Fortress Back Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by pulling it away from the back of the phone.
  3. HTC Fortress Back Panel Replacement, SIM Card: 步骤 3 中的图像 1,3 HTC Fortress Back Panel Replacement, SIM Card: 步骤 3 中的图像 2,3 HTC Fortress Back Panel Replacement, SIM Card: 步骤 3 中的图像 3,3
    • Insert the stylus into the small slot.
    • Use the stylus as a lever to push the sim card out of its fitting.
    • Use your finger to slide the card out the rest of the way.
  4. HTC Fortress Back Panel Replacement, Back Panel: 步骤 4 中的图像 1,2 HTC Fortress Back Panel Replacement, Back Panel: 步骤 4 中的图像 2,2
    • Remove the two 4mm-long screws using the T4 Torx Screwdriver.
    • Remove the two 3.5mm-long screws using the T4 Torx Screwdriver.
    • Keep the 4mm-long upper screws separate from the 3.5mm-long bottom screws. They are different!
  5. HTC Fortress Back Panel Replacement: 步骤 5 中的图像 1,3 HTC Fortress Back Panel Replacement: 步骤 5 中的图像 2,3 HTC Fortress Back Panel Replacement: 步骤 5 中的图像 3,3
    • Remove the camera panel by hand (black cover above the battery slot).
    • Be careful, there is a cable attached underneath the camera panel.
    • Gently pull the camera panel away from the phone to detach the cable.
    • During reassembly, reattach the cable by holding the silver-plated ending slightly above its slot and using the spudger to gently press it into its fitting. Then, insert the camera panel so it is flush with the back panel again.
  6. HTC Fortress Back Panel Replacement: 步骤 6 中的图像 1,3 HTC Fortress Back Panel Replacement: 步骤 6 中的图像 2,3 HTC Fortress Back Panel Replacement: 步骤 6 中的图像 3,3
    • Notice the 8 small clips around the perimeter of the phone shown here...
  7. HTC Fortress Back Panel Replacement: 步骤 7 中的图像 1,2 HTC Fortress Back Panel Replacement: 步骤 7 中的图像 2,2
    • ...and the 2 clips shown here.
    • Insert the spudger into the seam along the edge of phone, and gently pry the back panel from the keyboard. Follow the seam along the perimeter of the phone.
    • Only pry right next to the clips shown in the above step, as well as the clips next to the charging port.
  8. HTC Fortress Back Panel Replacement: 步骤 8 中的图像 1,2 HTC Fortress Back Panel Replacement: 步骤 8 中的图像 2,2
    • Remove the back panel by pulling it away from the phone.
    • Slide the panel downwards as you remove it, making sure to clear the charging port.
结论
另外一个人完成了本指南。
Lucas David
于04/19/13注册
540 声望
创作了9篇指南
团队
Cal Poly, Team 4-13, Maness Spring 2013 Cal Poly, Team 4-13, Maness Spring 2013 的会员
CPSU-MANESS-S13S4G13
4 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 673
