跳转到主内容
HTC Flyer Charging Port Replacement
你所需要的
  1. HTC Flyer Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,1
    • Remove the white portion of the top cover as shown. Push down on it to slide it off using just your fingers. Be careful not to break the clips holding it in place with removing it.
  2. HTC Flyer Charging Port Replacement: 步骤 2 中的图像 1,3 HTC Flyer Charging Port Replacement: 步骤 2 中的图像 2,3 HTC Flyer Charging Port Replacement: 步骤 2 中的图像 3,3
    • Remove the five Torx T5 screws.
  3. HTC Flyer Charging Port Replacement: 步骤 3 中的图像 1,2 HTC Flyer Charging Port Replacement: 步骤 3 中的图像 2,2
    • Remove full frame on the back. A tip is to tape the volume button to the frame before removing it, as the volume button will fall out.
  4. HTC Flyer Charging Port Replacement: 步骤 4 中的图像 1,2 HTC Flyer Charging Port Replacement: 步骤 4 中的图像 2,2
    • Remove the plastic top cover of the motherboard.
  5. HTC Flyer Charging Port Replacement: 步骤 5 中的图像 1,2 HTC Flyer Charging Port Replacement: 步骤 5 中的图像 2,2
    • Remove four T5 Torx screws.
  6. HTC Flyer Charging Port Replacement: 步骤 6 中的图像 1,3 HTC Flyer Charging Port Replacement: 步骤 6 中的图像 2,3 HTC Flyer Charging Port Replacement: 步骤 6 中的图像 3,3
    • Remove twelve of the connectors.
  7. HTC Flyer Charging Port Replacement: 步骤 7 中的图像 1,2 HTC Flyer Charging Port Replacement: 步骤 7 中的图像 2,2
    • Release the flex-screen touch cable. It is held in place with clips. Use the safe open pry tool to unclip it. Note that it will still be connected to the base and the motherboard.
  8. HTC Flyer Charging Port Replacement: 步骤 8 中的图像 1,1
    • Flip the motherboard and the flex screen to the left.
  9. HTC Flyer Charging Port Replacement: 步骤 9 中的图像 1,1
    • Release the two file cables attached to the motherboard.
  10. HTC Flyer Charging Port Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard. Note that the flex screen will not be removed with it and will remain attached to the tablet frame.
  11. HTC Flyer Charging Port Replacement: 步骤 11 中的图像 1,3 HTC Flyer Charging Port Replacement: 步骤 11 中的图像 2,3 HTC Flyer Charging Port Replacement: 步骤 11 中的图像 3,3
  12. HTC Flyer Charging Port Replacement: 步骤 12 中的图像 1,2 HTC Flyer Charging Port Replacement: 步骤 12 中的图像 2,2
    • Remove the dock port flex cable. It will be tangled around other cables, so take care not to rip it while removing.
结论
Joshua Mahon
于11/26/18注册
445 声望
创作了3篇指南
团队
IUPUI, Team S5-G5, Wilson Fall 2018 IUPUI, Team S5-G5, Wilson Fall 2018 的会员
IUPUI-WILSON-F18S5G5
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 362
