简介
Replacing the battery is a very simple task which only requires a screwdriver, a spudger, and replacement battery.
你所需要的
Apply pressure along the bottom of the white panel containing the camera and push upwards.
Remove the black protective piece of plastic by sliding it upwards.
Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
Remove the protective panel by sliding it upwards.
4等其他人完成本指南。
