跳转到主内容
加入维修社区 - 创建账户
HTC Flyer Back Cover Replacement
你所需要的
  1. HTC Flyer Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 HTC Flyer Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 HTC Flyer Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
  2. HTC Flyer Back Cover Replacement: 步骤 2 中的图像 1,3 HTC Flyer Back Cover Replacement: 步骤 2 中的图像 2,3 HTC Flyer Back Cover Replacement: 步骤 2 中的图像 3,3
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
  3. HTC Flyer Back Cover Replacement: 步骤 3 中的图像 1,3 HTC Flyer Back Cover Replacement: 步骤 3 中的图像 2,3 HTC Flyer Back Cover Replacement: 步骤 3 中的图像 3,3
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
  4. HTC Flyer Back Cover Replacement: 步骤 4 中的图像 1,2 HTC Flyer Back Cover Replacement: 步骤 4 中的图像 2,2
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
结论
2等其他人完成本指南。
Justin Funk
于10/07/14注册
473 声望
创作了3篇指南
团队
USF Tampa, Team 8-5, Leahy Fall 2014 USF Tampa, Team 8-5, Leahy Fall 2014 的会员
USFT-LEAHY-F14S8G5
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 28
总计 598
