简介
Replacing a broken or unresponsive HTC EXCA100 Keyboard
你所需要的
Remove the rubber screw covers. If needed, use a thin object to help pry them off. There should be two of them on top of the phone. Skip this step if already removed.
Pry loose the metal cover near the camera lens, circled in the picture.
Remove the metal frame. Slip out the copper clips still attached to the bottom frame from the frame carefully.
即将完成!
结论
