跳转到主内容
加入维修社区 - 创建账户
HTC Evo 4G Rear Inner Frame Replacement
你所需要的
  1. HTC Evo 4G Rear Inner Frame Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
    询问修复机器人
    添加评论
  2. HTC Evo 4G Rear Inner Frame Replacement: 步骤 2 中的图像 1,1
    • Lift the rear panel off of the inner rear frame.
    询问修复机器人
    添加评论
  3. HTC Evo 4G Rear Inner Frame Replacement, Battery: 步骤 3 中的图像 1,2 HTC Evo 4G Rear Inner Frame Replacement, Battery: 步骤 3 中的图像 2,2
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
    询问修复机器人
    添加评论
  4. HTC Evo 4G Rear Inner Frame Replacement, MicroSD card: 步骤 4 中的图像 1,1
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
    询问修复机器人
    添加评论
  5. HTC Evo 4G Rear Inner Frame Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
    询问修复机器人
    添加评论
  6. HTC Evo 4G Rear Inner Frame Replacement, Rear Inner Frame: 步骤 6 中的图像 1,1
    • Remove six T5 Torx screws securing the rear inner frame to the inner case.
    询问修复机器人
    添加评论
  7. HTC Evo 4G Rear Inner Frame Replacement: 步骤 7 中的图像 1,1
    • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
    • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
    询问修复机器人
    添加评论
  8. HTC Evo 4G Rear Inner Frame Replacement: 步骤 8 中的图像 1,2 HTC Evo 4G Rear Inner Frame Replacement: 步骤 8 中的图像 2,2
    • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
    询问修复机器人
    添加评论
  9. HTC Evo 4G Rear Inner Frame Replacement: 步骤 9 中的图像 1,3 HTC Evo 4G Rear Inner Frame Replacement: 步骤 9 中的图像 2,3 HTC Evo 4G Rear Inner Frame Replacement: 步骤 9 中的图像 3,3
    • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
    • Pry up the rear inner frame along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
    询问修复机器人
    添加评论
  10. HTC Evo 4G Rear Inner Frame Replacement: 步骤 10 中的图像 1,1
    • Remove the rear inner frame from the rest of the Evo.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
1指南评论
You may want people to also know they have to remove the lcd panel and the rear speaker to install them in their new rear inner panel.
Tony Stone - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 69
总计 12,526
