跳转到主内容
简介
Use this guide to remove or replace your current MicroSD card.
  1. Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
  2. Lift the rear panel off of the inner rear frame.
    • Lift the rear panel off of the inner rear frame.
  3. Using the tip of your finger, lift the battery from the end closest to the camera. Remove the battery from the rear inner frame.
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  4. Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
  5. Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
结论
7等其他人完成本指南。
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 5
总计 10,196
