跳转到主内容
HTC Evo 3D Speaker Replacement
你所需要的
  1. HTC Evo 3D Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 HTC Evo 3D Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 HTC Evo 3D Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Speaker Replacement: 步骤 2 中的图像 1,2 HTC Evo 3D Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the battery with your hands, lifting at the marked area.
    • Remove the SD card by pulling down on the bottom of the card.
  3. HTC Evo 3D Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the four T5 screws using the cooresponding screwdriver.
    • Remove the two J000 screws using the cooresponding screwdriver.
  4. HTC Evo 3D Speaker Replacement: 步骤 4 中的图像 1,2 HTC Evo 3D Speaker Replacement: 步骤 4 中的图像 2,2
    • With the battery removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • The marked part in the second photo is the speaker.
  5. HTC Evo 3D Speaker Replacement: 步骤 5 中的图像 1,3 HTC Evo 3D Speaker Replacement: 步骤 5 中的图像 2,3 HTC Evo 3D Speaker Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • The speaker can be loosened from its glue with the spudger.
    • Pry from the bottom with constant pressure to loosen one end of the speaker.
    • When the speaker is sufficiently loosened, completely remove it by grabbing it with the precision tweezers.
  6. HTC Evo 3D Speaker Replacement: 步骤 6 中的图像 1,1
    • With the old speaker removed, insert the new speaker in the same place.
    • When reinserting the new speaker, be sure that the golden contacts (As previously marked) are facing up.
结论
To reassemble your device, follow these instructions in reverse order but with a new speaker.
另外一个人完成了本指南。
James Burke
于08/26/15注册
245 声望
创作了2篇指南
团队
USF Tampa, Team 14-20, Meier Fall 2015 USF Tampa, Team 14-20, Meier Fall 2015 的会员
USFT-MEIER-F15S14G20
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 335
