跳转到主内容
HTC Evo 3D Motherboard Replacement
你所需要的
  1. HTC Evo 3D Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 HTC Evo 3D Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 HTC Evo 3D Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Motherboard Replacement: 步骤 2 中的图像 1,2 HTC Evo 3D Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the battery with your hands, lifting at the marked area.
    • Remove the SD card by gently pulling down on the bottom of the card.
  3. HTC Evo 3D Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the four T5 screws using the corresponding screwdriver.
    • Remove the two J000 screws using the corresponding screwdriver.
  4. HTC Evo 3D Motherboard Replacement: 步骤 4 中的图像 1,2 HTC Evo 3D Motherboard Replacement: 步骤 4 中的图像 2,2
    • With the battery, SD card, and screws removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • Be sure not to rip or damage the ribbons inside this shell.
  5. HTC Evo 3D Motherboard Replacement: 步骤 5 中的图像 1,3 HTC Evo 3D Motherboard Replacement: 步骤 5 中的图像 2,3 HTC Evo 3D Motherboard Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Pictured here is the motherboard.
    • Using precision tweezers, remove the flash mechanism by prying the sides of the piece.
  6. HTC Evo 3D Motherboard Replacement: 步骤 6 中的图像 1,3 HTC Evo 3D Motherboard Replacement: 步骤 6 中的图像 2,3 HTC Evo 3D Motherboard Replacement: 步骤 6 中的图像 3,3
    • Next we will remove the vibration mechanism shown here.
    • Using precision tweezers or fingers, gently pull on the wires connecting the vibration mechanism to the motherboard.
    • The piece should come loose easily.
  7. HTC Evo 3D Motherboard Replacement: 步骤 7 中的图像 1,3 HTC Evo 3D Motherboard Replacement: 步骤 7 中的图像 2,3 HTC Evo 3D Motherboard Replacement: 步骤 7 中的图像 3,3
    • The next step is to disconnect all ribbons attached to the motherboard.
    • Begin by using tweezers to remove the plastic covering the ribbons.
    • Each ribbon needs to be removed by unlocking the white tab and pulling on the ribbon.
    • Unlock by lifting the white tab directly up.
    • The ribbons easily rip and require careful handling.
  8. HTC Evo 3D Motherboard Replacement: 步骤 8 中的图像 1,2 HTC Evo 3D Motherboard Replacement: 步骤 8 中的图像 2,2
    • At this point the motherboard is almost fully detached.
    • Lift the motherboard and using precision tweezers, peel up the insulation cover on the bottom left corner.
  9. HTC Evo 3D Motherboard Replacement: 步骤 9 中的图像 1,3 HTC Evo 3D Motherboard Replacement: 步骤 9 中的图像 2,3 HTC Evo 3D Motherboard Replacement: 步骤 9 中的图像 3,3
    • Disconnect the two ribbons on the backside of the mother board using precision tweezers.
    • Disconnect the Cellular/WIFI antenna by pulling directly up on the black wire.
    • The motherboard will now be free from the rest of the phone.
结论
3等其他人完成本指南。
Matthew Pope
于08/26/15注册
441 声望
创作了2篇指南
团队
USF Tampa, Team 14-20, Meier Fall 2015 USF Tampa, Team 14-20, Meier Fall 2015 的会员
USFT-MEIER-F15S14G20
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 912
