跳转到主内容
HTC EVO Design 4G Screen Replacement
你所需要的
  1. HTC EVO Design 4G Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
  2. HTC EVO Design 4G Screen Replacement, Removing Casing: 步骤 2 中的图像 1,1
    • Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
  3. HTC EVO Design 4G Screen Replacement, Removing Battery: 步骤 3 中的图像 1,2 HTC EVO Design 4G Screen Replacement, Removing Battery: 步骤 3 中的图像 2,2
    • When open, pull on “Open” tab and it should rotate towards you
    • Grab the bottom edge of the battery and pull it toward you
  4. HTC EVO Design 4G Screen Replacement, Removing Casing: 步骤 4 中的图像 1,2 HTC EVO Design 4G Screen Replacement, Removing Casing: 步骤 4 中的图像 2,2
    • On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it
    • Info*: The adhesive tape that you may find will not be necessary for replacement later
  5. HTC EVO Design 4G Screen Replacement, Removing Screws: 步骤 5 中的图像 1,2 HTC EVO Design 4G Screen Replacement, Removing Screws: 步骤 5 中的图像 2,2
    • Remove the two Phillips screws to release the casing above the port
    • Remove the top and bottom pairs of Torx screws.
    • Remove the middle pair of two Phillips screws.
  6. HTC EVO Design 4G Screen Replacement, Removing Casing: 步骤 6 中的图像 1,3 HTC EVO Design 4G Screen Replacement, Removing Casing: 步骤 6 中的图像 2,3 HTC EVO Design 4G Screen Replacement, Removing Casing: 步骤 6 中的图像 3,3
    • To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
  7. HTC EVO Design 4G Screen Replacement, Removing Screws Continued: 步骤 7 中的图像 1,2 HTC EVO Design 4G Screen Replacement, Removing Screws Continued: 步骤 7 中的图像 2,2
    • Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
  8. HTC EVO Design 4G Screen Replacement, Removing Rear Housing: 步骤 8 中的图像 1,2 HTC EVO Design 4G Screen Replacement, Removing Rear Housing: 步骤 8 中的图像 2,2
    • Remove the rear housing by prying around the edge with your Safety Pry Tool
  9. HTC EVO Design 4G Screen Replacement, Pull the Plug: 步骤 9 中的图像 1,1
    • Unplug the wire connecting the vibrator to the board with your tweezers
  10. HTC EVO Design 4G Screen Replacement, Like a Book: 步骤 10 中的图像 1,1
    • Unfold motherboard from the screen (open carefully like a book)
  11. HTC EVO Design 4G Screen Replacement, Flex Cables: 步骤 11 中的图像 1,1
    • Disconnect the two aluminum flex cables
  12. HTC EVO Design 4G Screen Replacement, Broken Bond: 步骤 12 中的图像 1,1
    • The flex cables should be the only binding and after being removed should leave you with the separate screen
结论
Replace the screen and to reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Victoria
于10/23/14注册
94 声望
创作了3篇指南
团队
UMass Dartmouth, Team 5-4, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-4, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 9
总计 609
