你所需要的
Tools Needed: 1. Safety pry tool (guitar pick), 2. Tweezers, 3. Phillips Screwdriver, 4. Star tip Precision Screwdriver, 5. Flathead Screwdriver
Use your safety pry tool on the outside edges of the back casing to lift and remove it
Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off
Remove old lens.
Place replacement lens over the camera lens and it should loosely snap on
Info*: Don’t worry if the cover is loose because the cover of the phone would hold it in place
2等其他人完成本指南。
