这个步骤还没有翻译 帮忙翻译一下
Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
Remove the battery from the phone by carefully lifting it out with your fingers.
Set the battery aside for disposal. You are now ready to insert a new battery.
you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
Using the plastic opening tools again, gently pry the inner frame apart from the rest of the phone
Remove the inner frame from the rest of the phone by lifting it off
Remove the five screws that are holding the stand in place.
Remove the stand from the frame by lifting it out. Clear any debis causing it to be jammed, or replace with new stand.
取消:我没有完成这个指南。
与3其他贡献者
于03/13/14注册
1,128 声望
创作了4篇指南
徽章: 11
+ 8更多徽章
NMSU-EASLEY-S14S1G1
5 名成员
创作了5篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 145
