简介
Is your Droid Incredible not sounding so incredible? Use this guide to replace the rear speaker.
你所需要的
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
Press the MicroSD card further into its slot until it clicks.
Release the MicroSD card, and it will pop out slightly.
Remove four T6 Torx screws securing the rear inner frame to the front case.
To reassemble your device, follow these instructions in reverse order. Note that the spring contacts on the rear speaker must face toward the outside of the device, to connect with the logic board.
