跳转到主内容
HTC Droid Incredible MicroSD card Replacement
  1. HTC Droid Incredible MicroSD card Replacement, Battery: 步骤 1 中的图像 1,3 HTC Droid Incredible MicroSD card Replacement, Battery: 步骤 1 中的图像 2,3 HTC Droid Incredible MicroSD card Replacement, Battery: 步骤 1 中的图像 3,3
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible MicroSD card Replacement: 步骤 2 中的图像 1,1
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible MicroSD card Replacement: 步骤 3 中的图像 1,3 HTC Droid Incredible MicroSD card Replacement: 步骤 3 中的图像 2,3 HTC Droid Incredible MicroSD card Replacement: 步骤 3 中的图像 3,3
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  4. HTC Droid Incredible MicroSD card Replacement, MicroSD card: 步骤 4 中的图像 1,2 HTC Droid Incredible MicroSD card Replacement, MicroSD card: 步骤 4 中的图像 2,2
    • Press the MicroSD card further into its slot until it clicks.
    • Release the MicroSD card, and it will pop out slightly.
  5. HTC Droid Incredible MicroSD card Replacement: 步骤 5 中的图像 1,2 HTC Droid Incredible MicroSD card Replacement: 步骤 5 中的图像 2,2
    • Pull the MicroSD card straight out of its slot.
结论
另外一个人完成了本指南。
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 2,095
