跳转到主内容
简介
Use this guide to replace or upgrade the battery in your Droid Incredible.
  1. HTC Droid Incredible Battery Replacement, Battery: 步骤 1 中的图像 1,3 HTC Droid Incredible Battery Replacement, Battery: 步骤 1 中的图像 2,3 HTC Droid Incredible Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible Battery Replacement: 步骤 3 中的图像 1,3 HTC Droid Incredible Battery Replacement: 步骤 3 中的图像 2,3 HTC Droid Incredible Battery Replacement: 步骤 3 中的图像 3,3
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
结论
另外一个人完成了本指南。
Andrew Optimus Goldheart
于2009年10月17日注册
489,792 声望
创作了410篇指南
团队
iFixit iFixit 的会员
Community
147 名成员
创作了16,036篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,495
