跳转到主内容
HTC Droid Eris Battery Replacement
你所需要的
  1. HTC Droid Eris Battery Replacement, Battery: 步骤 1 中的图像 1,2 HTC Droid Eris Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the device on a flat surface with the headphone outlet/jack facing away from you.
    • Place one of your fingers on the opposite corner of the headphone outlet/jack where there is a sliver of space. Be sure not to touch the front screen.
    • Next, pull the back cover upwards and off. If this feels difficult, use the spudger, and wedge it between the covers to pry off.
  2. HTC Droid Eris Battery Replacement: 步骤 2 中的图像 1,2 HTC Droid Eris Battery Replacement: 步骤 2 中的图像 2,2
    • Once the cover is off, lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place with the half-moon gap facing away from you [marked].
    • The square piece in the center of the phone is the battery. With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you to remove.
    • If the battery is not coming out with this technique, use the iFixit plastic opening tool to pop it out of its holdings.
结论
Elizabeth Ofori
于04/15/13注册
648 声望
创作了6篇指南
团队
SUNY Cortland, Team 1-2, Getto Spring 2013 SUNY Cortland, Team 1-2, Getto Spring 2013 的会员
SUNYCORT-GETTO-S13S1G2
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 879
