简介
This guide will show you how to remove and replace the camera module of the HTC Desire V smartphone.
你所需要的
Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
Remove the black information sticker if this is the first time opening the handset.
在这个步骤中使用的工具:Tweezers$4.99
You should now see a black ribbon cable, which was connected at the left to the Nav board, and on the right, to a gold ribbon cable which goes to the screen.
Unlock the gold ribbon cable connecting screen to logic board by lifting the locking tab at the back of the socket.
For this you may wish to use a spudger or tweezers.
Noting that the rear side of the black ribbon cable is gold, use a spudger or an opening tool to gently disconnect it from the motherboard by levering it up at the right side
