简介
This guide will outline how to remove the logic board assembly, including cables, from the HTC Desire V smartphone
你所需要的
Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
Remove the black information sticker if this is the first time opening the handset.
在这个步骤中使用的工具:Tweezers$4.99
You should now see a black ribbon cable, which was connected at the left to the Nav board, and on the right, to a gold ribbon cable which goes to the screen.
Unlock the gold ribbon cable connecting screen to logic board by lifting the locking tab at the back of the socket.
For this you may wish to use a spudger or tweezers.
另外一个人完成了本指南。
