跳转到主内容
HTC Desire V Button Assembly Replacement
你所需要的
  1. HTC Desire V Button Assembly Replacement, Battery: 步骤 1 中的图像 1,3 HTC Desire V Button Assembly Replacement, Battery: 步骤 1 中的图像 2,3 HTC Desire V Button Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Button Assembly Replacement: 步骤 2 中的图像 1,3 HTC Desire V Button Assembly Replacement: 步骤 2 中的图像 2,3 HTC Desire V Button Assembly Replacement: 步骤 2 中的图像 3,3
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Button Assembly Replacement, Midframe: 步骤 3 中的图像 1,3 HTC Desire V Button Assembly Replacement, Midframe: 步骤 3 中的图像 2,3 HTC Desire V Button Assembly Replacement, Midframe: 步骤 3 中的图像 3,3
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Button Assembly Replacement: 步骤 4 中的图像 1,3 HTC Desire V Button Assembly Replacement: 步骤 4 中的图像 2,3 HTC Desire V Button Assembly Replacement: 步骤 4 中的图像 3,3
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Button Assembly Replacement, Button Assembly: 步骤 5 中的图像 1,2 HTC Desire V Button Assembly Replacement, Button Assembly: 步骤 5 中的图像 2,2
    • Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
  6. HTC Desire V Button Assembly Replacement: 步骤 6 中的图像 1,2 HTC Desire V Button Assembly Replacement: 步骤 6 中的图像 2,2
    • Gently unplug and remove aerial cable (black antenna) from bottom plug.
  7. HTC Desire V Button Assembly Replacement: 步骤 7 中的图像 1,2 HTC Desire V Button Assembly Replacement: 步骤 7 中的图像 2,2
    • Nav Board will be stuck down by glue.
    • Pull gently from the right end of the board, being careful of its flexibility.
结论
3等其他人完成本指南。
William McCusker
于01/29/15注册
1,096 声望
创作了9篇指南
团队
Clemson, Team 14-3, Shirley Winter 2015 Clemson, Team 14-3, Shirley Winter 2015 的会员
CLEM-SHIRLEY-W15S14G3
6 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 316
