跳转到主内容
HTC Desire 816 Top Speaker Replacement
你所需要的
  1. HTC Desire 816 Top Speaker Replacement, Top Speaker: 步骤 1 中的图像 1,1
    • Using the T5 screw driver, unscrew all of the screws that are holding down the black plastic casing.
  2. HTC Desire 816 Top Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the black plastics casing surrounding the motherboard with a plastic opening tool.
  3. HTC Desire 816 Top Speaker Replacement: 步骤 3 中的图像 1,1
    • Using the PH000 screwdriver head, unscrew the screw that is holding down the motherboard. It is located on the left side of the motherboard.
  4. HTC Desire 816 Top Speaker Replacement: 步骤 4 中的图像 1,1
    • Using a pair of tweezers disconnect the battery from the motherboard so that the motherboard could later be removed from the device.
  5. HTC Desire 816 Top Speaker Replacement: 步骤 5 中的图像 1,1
    • Once you have flipped the motherboard over, you should be able to locate the speaker at the top of the phone.
  6. HTC Desire 816 Top Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove top speaker gently with a pair of tweezers.
    • The speaker is also connected to a flat black plastic casing which will also be removed as you lift the speaker
结论
另外一个人完成了本指南。
Edward Garcia
于03/25/16注册
527 声望
撰写一个指南
团队
UMass Dartmouth, Team 5-3, Landers Spring 2016 UMass Dartmouth, Team 5-3, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,266
