跳转到主内容
HTC Desire 816 Battery Replacement
你所需要的
  1. HTC Desire 816 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
  2. HTC Desire 816 Battery Replacement: 步骤 2 中的图像 1,1
    • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
  3. HTC Desire 816 Battery Replacement: 步骤 3 中的图像 1,1
    • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
    • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  4. HTC Desire 816 Battery Replacement: 步骤 4 中的图像 1,1
    • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
  5. HTC Desire 816 Battery Replacement: 步骤 5 中的图像 1,1
    • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
  6. HTC Desire 816 Battery Replacement: 步骤 6 中的图像 1,1
    • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
  7. HTC Desire 816 Battery Replacement: 步骤 7 中的图像 1,1
    • Carefully lift battery backside first to disconnect the white connector.
结论
12等其他人完成本指南。
团队
UMass Dartmouth, Team 5-3, Landers Spring 2016 UMass Dartmouth, Team 5-3, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G3
3 名成员
创作了12篇指南
一条评论
Very clear and helpful guide, thank you. I wonder though, is it necessary to remove tape residue from case before re-affixing, and if so how?
doorite2 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 21
总计 14,372
