跳转到主内容
HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement
你所需要的
  1. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Removing Battery: 步骤 2 中的图像 1,1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Remove 8 Torx Screws: 步骤 3 中的图像 1,1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Prying Off Rear Panel: 步骤 4 中的图像 1,1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): 步骤 5 中的图像 1,1
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  6. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement: 步骤 6 中的图像 1,1
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
结论
Steven Pate
于09/23/14注册
191 声望
创作了7篇指南
团队
USF Tampa, Team 9-3, Blackwell Fall 2014 USF Tampa, Team 9-3, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,067
