跳转到主内容
HTC Desire 700 Dual Sim Motherboard Replacement
你所需要的
  1. HTC Desire 700 Dual Sim Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Motherboard Replacement, Removing Battery: 步骤 2 中的图像 1,1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Motherboard Replacement, Remove 8 Torx Screws: 步骤 3 中的图像 1,1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Motherboard Replacement, Prying Off Rear Panel: 步骤 4 中的图像 1,1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  6. HTC Desire 700 Dual Sim Motherboard Replacement, Disconnect Vibrator Wire: 步骤 6 中的图像 1,1
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  7. HTC Desire 700 Dual Sim Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove volume control button ribbon with tweezers.
  8. HTC Desire 700 Dual Sim Motherboard Replacement: 步骤 8 中的图像 1,1
    • Carefully remove the ribbon attached to the top of the motherboard.
  9. HTC Desire 700 Dual Sim Motherboard Replacement: 步骤 9 中的图像 1,1
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
结论
2等其他人完成本指南。
Steven Pate
于09/23/14注册
191 声望
创作了7篇指南
团队
USF Tampa, Team 9-3, Blackwell Fall 2014 USF Tampa, Team 9-3, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,767
