跳转到主内容
HTC Desire 700 Dual Sim Bottom Speaker Replacement
你所需要的
  1. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Removing Battery: 步骤 2 中的图像 1,1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Remove 8 Torx Screws: 步骤 3 中的图像 1,1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Prying Off Rear Panel: 步骤 4 中的图像 1,1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Printed Circuit Board (PCB): 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  6. HTC Desire 700 Dual Sim Bottom Speaker Replacement: 步骤 6 中的图像 1,1
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
  7. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Bottom Speaker: 步骤 7 中的图像 1,1
    • Using the spudger, pry the speaker away from the screen.
结论
3等其他人完成本指南。
Steven Pate
于09/23/14注册
196 声望
创作了7篇指南
团队
USF Tampa, Team 9-3, Blackwell Fall 2014 USF Tampa, Team 9-3, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G3
4 名成员
创作了14篇指南
1指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,007
