跳转到主内容
HTC Desire 626s Backplate Replacement
你所需要的
  1. HTC Desire 626s Backplate Replacement, Backplate: 步骤 1 中的图像 1,3 HTC Desire 626s Backplate Replacement, Backplate: 步骤 1 中的图像 2,3 HTC Desire 626s Backplate Replacement, Backplate: 步骤 1 中的图像 3,3
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Backplate Replacement: 步骤 2 中的图像 1,2 HTC Desire 626s Backplate Replacement: 步骤 2 中的图像 2,2
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Backplate Replacement: 步骤 3 中的图像 1,2 HTC Desire 626s Backplate Replacement: 步骤 3 中的图像 2,2
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 261
