跳转到主内容
HTC Desire 530 Speaker Replacement
你所需要的
  1. HTC Desire 530 Speaker Replacement, Battery: 步骤 1 中的图像 1,2 HTC Desire 530 Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Use the plastic opening tools to remove the plastic speaker covers that are attached through an adhesive layer.
    • They may be difficult to peel off and you might want to consider loosening the adhesive layer by running a hair dryer or a heat gun over it briefly to allow them to peel off easily.
  2. HTC Desire 530 Speaker Replacement: 步骤 2 中的图像 1,3 HTC Desire 530 Speaker Replacement: 步骤 2 中的图像 2,3 HTC Desire 530 Speaker Replacement: 步骤 2 中的图像 3,3
    • Use the T5 Torx screwdriver to remove the four screws in each corner.
    • Make sure to take out any SD cards, located on the left side of the phone before proceeding to the next step.
    • Use the plastic opening tool to pry the front of the device off. Fully go around the front with the plastic opening tool before attempting to pull it off.
  3. HTC Desire 530 Speaker Replacement: 步骤 3 中的图像 1,3 HTC Desire 530 Speaker Replacement: 步骤 3 中的图像 2,3 HTC Desire 530 Speaker Replacement: 步骤 3 中的图像 3,3
    • Dislocate the small piece with the wires connected using a nylon spudger.
    • Loosen the adhesive layer for the battery by running a hair dryer over it briefly. After the adhesive is loosened you can pry the battery out with a plastic opening tool.
  4. HTC Desire 530 Speaker Replacement: 步骤 4 中的图像 1,2 HTC Desire 530 Speaker Replacement: 步骤 4 中的图像 2,2
    • After prying, simply lift the battery up and out of the device.
  5. HTC Desire 530 Speaker Replacement, Speaker: 步骤 5 中的图像 1,3 HTC Desire 530 Speaker Replacement, Speaker: 步骤 5 中的图像 2,3 HTC Desire 530 Speaker Replacement, Speaker: 步骤 5 中的图像 3,3
    • Use the T5 Torx screwdriver to remove the screw located on the left side.
    • Use the spudger to slowly pry off the black cover.
    • Slowly pry off the circuit board with the spudger in a very cautious manner.
  6. HTC Desire 530 Speaker Replacement: 步骤 6 中的图像 1,3 HTC Desire 530 Speaker Replacement: 步骤 6 中的图像 2,3 HTC Desire 530 Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the rubber object by pinching and pulling it out.
    • Take the speaker out of the holder.
  7. HTC Desire 530 Speaker Replacement: 步骤 7 中的图像 1,3 HTC Desire 530 Speaker Replacement: 步骤 7 中的图像 2,3 HTC Desire 530 Speaker Replacement: 步骤 7 中的图像 3,3
    • To access the top speaker, you must first detach the orange cable from its holder with your fingers.
    • Remove the T5 Torx screw.
    • Carefully pry off the circular object with the spudger.
    • Do not accidentally disconnect this object from the phone. It is connected by 2 short wires.
  8. HTC Desire 530 Speaker Replacement: 步骤 8 中的图像 1,3 HTC Desire 530 Speaker Replacement: 步骤 8 中的图像 2,3 HTC Desire 530 Speaker Replacement: 步骤 8 中的图像 3,3
    • Use the spudger to carefully work your way around the edge of the motherboard and slowly pry it off.
    • Use the spudger to pry off the speaker.
结论
Thomas Morin
于10/25/18注册
241 声望
创作了2篇指南
团队
UMASSD-PEAK-F18S3G2 UMASSD-PEAK-F18S3G2 的会员
Community
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 402
