跳转到主内容
HTC Desire 530 Micro USB Port Replacement
你所需要的
  1. HTC Desire 530 Micro USB Port Replacement, Micro USB Port: 步骤 1 中的图像 1,1
    • Remove the four 1.2mm screws in each corner.
    • Use the suction cup and plastic opening tool to pry the screen from the body.
  2. HTC Desire 530 Micro USB Port Replacement: 步骤 2 中的图像 1,1
    • Gently pry the battery up at these three spots, and disconnect the power cables attached.
  3. HTC Desire 530 Micro USB Port Replacement: 步骤 3 中的图像 1,1
    • You can then fold the battery back like so, and that will give you access to the screw.
  4. HTC Desire 530 Micro USB Port Replacement: 步骤 4 中的图像 1,1
    • Use the screwdriver to remove the 1.2 mm screw at the bottom of the phone.
  5. HTC Desire 530 Micro USB Port Replacement: 步骤 5 中的图像 1,1
    • Once the screw and the black plastic backing are removed the daughterboard pulls right out.
  6. HTC Desire 530 Micro USB Port Replacement: 步骤 6 中的图像 1,1
    • In order to fix the Micro USB Port, the entire daughterboard will need to be replaced because all connections are soldered in.
结论
另外一个人完成了本指南。
Eric Blackstock
于10/24/18注册
403 声望
创作了2篇指南
团队
UMASSD-PEAK-F18S3G2 UMASSD-PEAK-F18S3G2 的会员
Community
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 627
