跳转到主内容
HTC Desire 530 Battery Replacement
你所需要的
  1. HTC Desire 530 Battery Replacement, Battery: 步骤 1 中的图像 1,2 HTC Desire 530 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Use the plastic opening tools to remove the plastic speaker covers that are attached through an adhesive layer.
    • They may be difficult to peel off and you might want to consider loosening the adhesive layer by running a hair dryer or a heat gun over it briefly to allow them to peel off easily.
  2. HTC Desire 530 Battery Replacement: 步骤 2 中的图像 1,3 HTC Desire 530 Battery Replacement: 步骤 2 中的图像 2,3 HTC Desire 530 Battery Replacement: 步骤 2 中的图像 3,3
    • Use the T5 Torx screwdriver to remove the four screws in each corner.
    • Make sure to take out any SD cards, located on the left side of the phone before proceeding to the next step.
    • Use the plastic opening tool to pry the front of the device off. Fully go around the front with the plastic opening tool before attempting to pull it off.
  3. HTC Desire 530 Battery Replacement: 步骤 3 中的图像 1,3 HTC Desire 530 Battery Replacement: 步骤 3 中的图像 2,3 HTC Desire 530 Battery Replacement: 步骤 3 中的图像 3,3
    • Dislocate the small piece with the wires connected using a nylon spudger.
    • Loosen the adhesive layer for the battery by running a hair dryer over it briefly. After the adhesive is loosened you can pry the battery out with a plastic opening tool.
  4. HTC Desire 530 Battery Replacement: 步骤 4 中的图像 1,2 HTC Desire 530 Battery Replacement: 步骤 4 中的图像 2,2
    • After prying, simply lift the battery up and out of the device.
结论
2等其他人完成本指南。
Alyssa
于10/24/18注册
205 声望
撰写一个指南
团队
UMASSD-PEAK-F18S3G2 UMASSD-PEAK-F18S3G2 的会员
Community
3 名成员
创作了10篇指南
2条评论
Mi phone is sealed no scrows on my phone HTC Desire 530 so haw can i get the Battery out
robert jelley - 回复
My phone is sealed so awe can i get the Battery out it is HTC desire 530
robert jelley - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 27
总计 4,209
