跳转到主内容
加入维修社区 - 创建账户
HTC Desire 510 Front and Main Cameras Replacement
你所需要的
视频概述
  1. HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: 步骤 1 中的图像 1,3 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: 步骤 1 中的图像 2,3 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: 步骤 1 中的图像 3,3
    • Switch off the phone, remove the battery and any installed SIM and memory cards.
    • Remove 7x Torx T5 screws.
    询问修复机器人
    添加评论
  2. HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: 步骤 2 中的图像 1,3 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: 步骤 2 中的图像 2,3 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: 步骤 2 中的图像 3,3
    • Use a plastic tool to remove the rear bezel.
    • The loudspeaker is on the inner side of the rear bezel.
    询问修复机器人
    添加评论
  3. HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: 步骤 3 中的图像 1,3 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: 步骤 3 中的图像 2,3 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: 步骤 3 中的图像 3,3
    • Disconnect the touch screen flex cable.
    • Disconnect the light sensor flex cable.
    • Unstuck the vibra-motor from the middle frame.
    • Remove the coaxial antenna cable from the middle frame.
    • The LCD display flex cable is connected to the bottom side of the board.
    询问修复机器人
    添加评论
  4. HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: 步骤 4 中的图像 1,3 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: 步骤 4 中的图像 2,3 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: 步骤 4 中的图像 3,3
    • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
    • Gently disconnect the LCD display flex cable.
    • Now remove the logic board.
    询问修复机器人
    添加评论
  5. HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: 步骤 5 中的图像 1,2 HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: 步骤 5 中的图像 2,2
    • Main / Rear camera.
    • New line.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
ZFix
于12/09/13注册
197,270 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
334 名成员
创作了1,701篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 1,825
